Timer circuit design
Discussion in 'The Projects Forum' started by tigerapna, Dec 14, 2011.
  1. tigerapna
    Dec 14, 2011
    73
    Hello, I am new to this forum so I would like to say HI .
    My current circuit consists of 3 24VDC relays that control 3 pumps. I want to add a timer safety circuit which checks to see if the pumps are on for an hour.
    If the pumps are on continiously for an hour, the timer circuit should switch off the relays until the reset button is pressed.
    I found this:
    http://www.reuk.co.uk/Timer-Circuits-With-4060B.htm
    but it energies the relay after the timer has pulsed . I wish to do the opposite and switch off the relay when the timer has pulsed and also reset the timer when the pump has switched off in normal operation.
    I don't know if that makes sense but any help would be greatly appreciated.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    You could hook up the pump through the Normally closed contacts of the relay instead of the normally open contacts (on a DPDT Relay) with the circuit above to get what you are looking for.
    How accurate did your 1hour timing need to be? Within seconds? Within minutes?
    What temperature conditions will the circuit be exposed to?
  3. tigerapna
    Dec 14, 2011
    73
    The one hour timing can be accurate within +/- 5 minutes.
    The temperature is around 30 degrees celcius.
