Timer 5 sec every 5h
Discussion in 'The Projects Forum' started by Terfysgol, Jun 22, 2016.
  1. Terfysgol
    Jun 22, 2016
    Hello everyone,
    i'm looking for a circuit that close a contact (or power a relay) for 5 sec every 5h.
    The circuit is going to be placed in a very small and sneaky place so smaller is better.
    i surf the web and the forum but i couldn't find a circuit that can be used so i want to ask you some sort of suggestions about the materials needed and the circuit.
    Thanks a lot
    Terfysgol
  2. GopherT
    Nov 23, 2012
    6,319
    4,043
    How accurately must the circuit abide by 5 hours and by 5 seconds? Real time or 4.7 to 5.3 good enough? Something else?
    Once started, does it simply repeat forever?
    Will the circuit be battery or wall plug adapter?
    What is the coil voltage and current of the relay?
  3. dannyf
    Sep 13, 2015
    2,196
    417
    Learn to code a mcu -> piece of cake.
  4. Marley
    Member
    Apr 4, 2016
    171
    46
    If you want physically small then a micro-controller is the answer. Something like a PIC12C508A has everything you need inside including the oscillator. 8-pin DIP. Could be done with a crystal oscillator, cmos divider chain and some logic but will be many components, complex and big.
  5. crutschow
    Mar 14, 2008
    13,505
    3,376
    The simplest non-micro way would likely be to use a CD4060 circuit such as here.
  6. Dodgydave
    Jun 22, 2012
    5,155
    772
    Use a cd4060.
  7. crutschow
    Mar 14, 2008
    13,505
    3,376
    Maybe to do the delay program itself, but not to learn how to program an mcu. :rolleyes:
    tracecom and GopherT like this.
  8. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    How about a PICAXE 08M2?
    - No external oscillator needed.
    - Cheap.
    - 8-pin DIP
    - No need to code in assembly. Program in BASIC.
    - Development software is free.
    - They provide a sample 4 or 5 line program to flash an LED. That could be adjusted to do 5 seconds on every 5 hours.
    Downside: you need a serial port to program it. Either you need an old computer that has one, or need to buy a USB-to-serial converter (not too expensive on eBay).
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    +1 for the PICAXE. :)
    Ken
  10. tracecom
    Apr 16, 2010
    3,879
    1,396
    Lots of USB to serial converters don't work with PICAXE due to inverted logic; problem can be solved with a couple of transistor inverters. Or you can buy the AXE-027 USB programming cable for about $20.
    Roderick Young likes this.
  11. Dodgydave
    Jun 22, 2012
    5,155
    772
