Timer 0 not start
Discussion in 'Embedded Systems and Microcontrollers' started by FroceMaster, Mar 31, 2015.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi.
    HAve this code.
    Code (Text):
    1. #include <htc.h>
    2. #include <stdio.h>
    3. #include <stdlib.h>
    4. #include "lcd.h"
    5. #include <string.h>
    6. __CONFIG (CLKOUTEN_OFF & FCMEN_ON & IESO_OFF & BOREN_OFF & CP_OFF & MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_INTOSC);//XT
    7. __CONFIG (LVP_ON & LPBOR_OFF & BOREN_ON & STVREN_ON & WRT_OFF);
    8. #define _XTAL_FREQ 16000000
    9.
    10. signed int lightintensity;
    11. unsigned int runs;
    12. bit on_housenumber;
    13.
    14.   union
    15. {
    16. unsigned int res;
    17. char bytes[2];
    18. }
    19. ADC;
    20. unsigned char ADC_num[6];
    21.
    22.
    23. static void interrupt isr(void)   // Here is interrupt function - the name is unimportant.
    24. {
    25.    if(TMR0IF)
    26.    {
    27.         //TMR2=0;
    28.         TMR0IF=0;
    29.         RC7=1;
    30.       }
    31.
    32.
    33. }// end interrupt
    34.
    35. void setup(void)
    36. {
    37.     SCS1=1;
    38.     SCS0=1;
    39. IRCF3=1;//16MHz clock speed
    40. IRCF2=1;
    41. IRCF1=1;
    42. IRCF0=1;
    43.
    44.
    45.
    46. // timer 0
    47. TMR0CS=0; //fosc/4
    48. PSA=0;// use prescale
    49. PS0=1;
    50. PS1=1; // prescale 1:64
    51. PS2=1;
    52.
    53.
    54.
    55. //Port analog / digital
    56. TRISA=0; //all port ud.
    57. TRISA1=1; //set a1 in
    58. TRISB=0; // out
    59. TRISC=0; //  out.
    60.
    61. ANSELA=0; // set all digital.
    62. ANSA1=1; //analog
    63. ANSELB=0;
    64. ANSELC=0;//turn off all analog functions
    65. ADFM=1;    //right justified
    66. ADPREF0=1;
    67. ADPREF1=0;
    68.
    69. TRIGSEL0=1; // use timer0 interrupt to measure analog
    70. TRIGSEL1=1;
    71. TRIGSEL2=0;
    72. TRIGSEL3=0;
    73. CHS0=1;  //an1
    74. CHS1=0;
    75. CHS2=0;
    76. CHS3=0;
    77. CHS4=0; // AN1  analog
    78.
    79.
    80. } //end setup
    81.
    82.
    83. void housenumber_on (void)
    84. {
    85. RC0=1;
    86. __delay_ms(1);
    87. RC0=0;
    88. RC1=1;
    89. __delay_ms(1);
    90. RC1=0;
    91. RC2=1;
    92. __delay_ms(1);
    93. RC2=0;
    94. RC3=1;
    95. __delay_ms(1);
    96. RC3=0;
    97. RC4=1;
    98. __delay_ms(1);
    99. RC4=0;
    100. RC5=1;
    101. __delay_ms(1);
    102. RC5=0;
    103. RC6=1;
    104. __delay_ms(1);
    105. RC6=0;
    106.
    107.   }
    108.
    109.
    110. void main (void)
    111. {
    112.
    113. setup();         //runs setup
    114.        ADON=1;
    115.        GIE = 0;  // Global interrupt
    116.
    117.          on_housenumber=0;
    118.      runs=0;
    119.            while (1)// runs loop
    120.
    121.        { runs++;
    122.            if (runs==500)
    123.            { runs=0;
    124.
    125.                 ADC.bytes[0]=ADRESL;
    126.                  ADC.bytes[1]=ADRESH;
    127.                  lightintensity = ADC.res;
    128.                      if (lightintensity>700)
    129.                  {  on_housenumber= 1;
    130.                     }
    131.                 else
    132.                 {on_housenumber=0;
    133.                 }
    134.
    135.
    136.
    137.            }
    138.            if (on_housenumber==0)
    139.            {
    140.                housenumber_on();
    141.                                 }
    142.
    143.          }//end while endless loop
    144. }//End main
    But the timer0 is not running, why ?
    Pic 16F1509 btw.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    How do you know that Timer0 is not running?
  3. FroceMaster
    Jan 28, 2012
    402
    just the function was not ok, and in the simulator it was not .
    HAve now testet in real life, and it Works,
    no problemo :)
