Timeout circuit
Discussion in 'The Projects Forum' started by dedinthewater, Dec 15, 2008.
  1. dedinthewater
    Dec 14, 2008
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The CD4013 is a dual D flip flop. The A and B designators identify the different sections. For quad devices, you would also have a C and D designator.
  3. dedinthewater
    Dec 14, 2008
    Thank you for pointing me in the right direction, much appreciated.
  4. dedinthewater
    Dec 14, 2008
    The device this timer needs to trigger has a rating of around 32mA using 12V DC...
    Having looked through the catalogues, I'm feeling that the 4013 is rated to a max of 8.8mA, which I believe means I would need to use a relay later in the circuit.
    In your opinion would I be better off finding 555 circuit to accomplish the same result (10 seconds power on, then power off until the power is reset)?
    Kind regards,
    R.
