Timed trigger counter?
SpiderSpartanju
Joined Apr 10, 2009
82
I've got this motion sensor circuit all put together and connected to my old laptop turned digital picture frame and it's working very well. http://forum.allaboutcircuits.com/showthread.php?t=28653 Only problem now is that the motion trigger stays on for about a second and every once in a while it stays on long enough to turn off the computer.
I'm wondering if anyone knows of a simple/low space way to make the relay trigger for 1 second only if the motion sensor is triggered twice in say 5 seconds. I thought about using a flip-flop, but I'm not sure how to set these up to achieve this. Maybe a J-K flip-flop with one input attached to a 555 timer with a heavy duty cycle?
I guess the other option would be something like a PIC, but I'd really like something that would use a little less space than either of these options.
Anyone have any ideas here? Thanks.
Dx3
Joined Jun 19, 2010
87
It's the "twice in 5 seconds" that stops me.
Another way is to use a 555 as a one shot so the PIR can stay on as long as it wants and the computer only sees a blip.
That's the best I can think of right now.
SpiderSpartanju
Joined Apr 10, 2009
82
Great idea! I thought about using a 555 for the input to a flip-flop, but that would be more than I really need here I guess. I could just use it to drive the relay or use the 555 to control a second transistor in series with the one attached to the motion sensor output. That should definitely take up less space than a PIC. Thanks.
