Timed rocker switch help
Discussion in 'The Projects Forum' started by lambchops, Jun 25, 2010.
  1. lambchops
    Jun 25, 2010
    Im just starting out a new project making engine pre-heaters for RC nitro engines but would like to include some sort of timed switch to stop things getting to hot if left unattended.
    Ive done a google search to see if there is any sort of timed switch available but have come up emtpy. What I need is a switch which will run of 12V DC and turn off after 5 mins, ive read you can do this with a circuit but need some help..
    John
  2. retched
    Dec 5, 2009
    5,201
    313
    A google search turned up empty? Are you sure you spelled google right? ;)
    "12v timer relays" got me 336,000 results...in .42 seconds.
    A 555 timer and a relay will do what you want.
