Timed Relay Switching ?? How please ??
Discussion in 'General Electronics Chat' started by makidoja, Feb 6, 2012.
Thread Status:
Not open for further replies.
  1. makidoja
    Feb 1, 2012
    Hi all
    I would like to make a control relay switch on and off 3 times, once per second, then wait until the circuit is reset before doing the same again.
    I have basic electronics skills but not messed with timers etc before
    So bacially when energised the circuit should wait 1 second then energise the relay 3 times in 3 seconds then stop untill the circuit is reset by re-powering the circuit.
    Any ideas if or how this could be done please?
    I can measure the relay resistance if required.
    Mak
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Simple seqeuncing like that is often done here on the forum using a 555 timer IC (as an oscillator) and a 4017 IC (as a simple sequencer). You could serach the forum for "555 and 4017" or "4017 sequencer".
    I think using a variation on that theme you could make 3 pulses for 3 seconds then stop.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Please try to understand. This isn't a matter of looks. This is for your and our safety.
    No matter how you disguise your automotive query, the fact remains: We do not provide the information you look for. You may look for info in the following sites: http://forum.allaboutcircuits.com/showthread.php?t=54400
    This thread will be closed. Do not try to push the matter any further.
Thread Status:
