Timed operation of a voltage source
Discussion in 'The Projects Forum' started by uzair, Dec 31, 2007.
  1. uzair
    Thread Starter Active Member
    Dec 26, 2007
    110
    I have an input D.C. signal in the form of a pulse.I want that signal to ignite my external power source and using that source, i want my circuit to operate for specified time limit.What device can do that conveniently?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It rather depends upon your input DC signal pulse. What voltage, how much current is available, and what is the duration of the pulse?
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Positive pulse or negative pulse?
    With proper conditioning, the pulse could trigger a 555 monostable. The monostable output could then control a MOSFET or other switch for your power supply.
  4. uzair
    Dec 26, 2007
    110
    ok can u give me the pin configuration of the timer(555) chip.
    thanks
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Look here for some information on the 555 timer.
    hgmjr
  6. uzair
    Dec 26, 2007
    110
    thanks hgmjr it will solve my problem.
