Timed 12v pulse
Discussion in 'The Projects Forum' started by Jpaytoncfd, Mar 11, 2009.
  1. Jpaytoncfd
    Mar 11, 2009
    10
    Hi im not new to electronics but im not that knolagable
    I am using a dual Coil latching relay to turn an ignition on and off. Using a rfid to turn on and a pulse from another device to turn it off. I also want it to turn off after like 15-30 mins. Someone sugested a compacitor but if I understand correctly that will charge up to a much higher voltage and release it at one which would overload the relay coil. The simpler the better someone also said I would have to use a microcontroler. I am considering haveing the relays mounted on a pcb board and would like to add the timer feature built it rather than trying to add it on later. My though was a compacitor and something that would only allow the 12v 100mA through and ground the rest. (to empty the compacitor)
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    When you type "compacitor," do you mean "comparator" or "capacitor?"
  3. Jpaytoncfd
    Mar 11, 2009
    10
    capacitor, sorry my spelling is horrable. ya after a period of 15 mins I need a 1-2 second pulse.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
