Time on/off delay
Discussion in 'The Projects Forum' started by inwo, Feb 5, 2014.
  1. inwo
    Nov 7, 2013
    2,435
    315
    Came up with what I think is a minimum component dual timer.
    Integrated trigger and time delay off.
    It's a solution for/from another thread.
    As I just woke up and drew it out before I forgot, I'm wondering if someone would check for errors?
    Low pulses trigger after reaching duty cycle set by R3-C3.
    Minimum time on set by R2-C2.
    Input low = always on.
    D1 keeps C2 low and ready for full delay off cycle.
    I don't know if this is unique or I've reinvented the wheel, but it seems to do what I need.
  2. #12
    Nov 30, 2010
    16,655
    7,293
    Just adding some labels.
    A bit scatter-brained right now. Can't seem to cerebrate.
    inwo likes this.
  3. inwo
    Nov 7, 2013
    2,435
    315
    Thanks for looking.
    Wish I could do that!:)
    The schematic sw I use didn't even have a 555. I had to build it.
    I see one problem already. The 1MEG will need to be a little larger to let pin 2 get down to 1/3 of supply and trigger reliably. (your helpful label reminded me)
    This is for a tank level indicator.
    http://forum.allaboutcircuits.com/showthread.php?t=94220
    I can't believe on/off timers are so hard to find.
    edit:
    Don't bother with the math.
    Times are immaterial.
    Just basic function is fine,
  4. #12
    Nov 30, 2010
    16,655
    7,293
    What? Add labels or cerebrate? :D
  5. #12
    Nov 30, 2010
    16,655
    7,293
    When power is applied, C3 immediately raises trigger above 1/3 Vcc and that sets the output low (no LED).
    When power is applied, pin 6 is low and waiting while R2 starts charging C2 towards 2/3 Vcc, therefore output is high.
    Illegal condition. Results undefined, and I haven't even gotten to the switch. We need somebody to simulate this to see if I'm wrong.
  6. inwo
    Nov 7, 2013
    2,435
    315
    Yeah, I'm hoping for simulation.
    I believe there are 555 gurus on here. If it works, I'd like to no if it's unique. (in a good way)
    If it doesn't work, someone can point me to a minimum timer, that does delay on AND delay off, from a low side switch.
    This is the only way I can build circuits. Waking up with an inspiration. I never learned how to learn from others.:(
    I may get time to build it tomorrow.
    Haven't worked with 555s for years, but still have parts. Maybe even a board that I can solder up.
    Thanks again.:)
  7. #12
    Nov 30, 2010
    16,655
    7,293
    Slow on and slow off seems like it can be done with a cmos Comparator or op-amp and an RC, which, after all, is what a TL555 is, but containing a bunch of decision makers.
    12V, resistor, SPDT switch, capacitor, Schmitt trigger, viola. Am I missing something?
  8. inwo
    Nov 7, 2013
    2,435
    315
    As you say, that's what a 555 timer is.
    If someone comes up with a <8 component dual delay with other components, I'll check it out. (not counting switch or indicator)
    I started with discrete components. Then thought, why? By the time you get trigger levels, latch, and hysteresis.
  9. tracecom
    Apr 16, 2010
    3,878
    1,396
    The circuit works after a fashion.
    Close S1 and hold it closed. After 4 seconds pin 3 goes high. Open S1 and after 4 seconds, pin 3 goes low.
    Simply closing S1 and releasing it before pin 3 goes high does nothing. Likewise, holding S1 closed keeps pin 3 high for the duration of the time S1 is closed plus 4 seconds.
    I suppose there is a use for the circuit, but it seems more likely to require a toggle switch for S1 than a momentary push button.
    inwo likes this.
  10. #12
    Nov 30, 2010
    16,655
    7,293
    I'm just too busy to really pay attention lately. Go to Off Topic and see my Lucky Day thread. I hope you have something to add to that thread.:)
  11. tracecom
    Apr 16, 2010
    3,878
    1,396
    Cerebrate, cerebrate. Dance to the music.
  12. inwo
    Nov 7, 2013
    2,435
    315
    Hope to get it built later.
    The push button will be a level sensor that is either on, off, or bouncing.
    From what you say it will work just as wanted.
    It will ignore some bounces-on and some bounces off.:)
  13. tracecom
    Apr 16, 2010
    3,878
    1,396
    Don't tell #12, but I can do it with a 50 cent micro-controller and a .1uF cap (not including the switch and indicator.)
  14. inwo
    Nov 7, 2013
    2,435
    315
    Put it together last night and it works as I had hoped.:)
