Time it takes for current in an inductive circuit to reach a steady value
Discussion in 'Homework Help' started by Thekosherpickle, Oct 21, 2009.
  1. Thekosherpickle
    Oct 21, 2009
    Hello to all, I am new to this forum, Im an electrical engineering Tech student in lexington, Ky i stumbled upon this website tonight while frustrated with a homework problem. This website appears to be a great studying resource.
    I have a question that im having trouble with.
    I apologize ahead of time if i havent provided enough info or a attachment of the circuit; this is my first time posting so any advice is appreciated.
    I am givin a simple circuit with a power source of 180V with a switch, a resistor R=60ohm, and an inductor L=3H.
    The question is how long is it until current reaches its steady value?
    1. The first step i took was finding a time constant T=L/R T=3H/60ohm =50ms
    2. I then found source current of the circuit; Is=V/R Is=180v/60ohm = 3A
    3. Then I tried setting the source current equal to this equation we learned in class; 3A=(1-e^-x) and x=t/T i dont know what to put in for t.
    The solution is 250ms.
    My question is, am I using the correct formula? am I attacking this correctly? Am I overthinking this? thank you for any help.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You are doing well ...
    You have correctly indicated for the series R-L circuit that
    i(t)=Im(1-exp(-t/T))
    In your case Im=3A, T=50ms
    Generally the exponential term is considered (by convention) to have "vanished" at exp(-5). [Since exp(-5) = 0.006738 is small cf 1]
    So for t/T=5 means that t=5T=250ms. In effect the response is taken as being at steady state when t>=250ms.
