Time-function,one reactive
Discussion in 'Homework Help' started by Alice10, Jan 6, 2015.
  1. Alice10
    Oct 3, 2014
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Which side of Rs is the more positive?
  3. Alice10
    Oct 3, 2014
    I would say the "south" side on Rs would be positive because the current goes in to the positive side of a resistor?
    But then the next question gets wrong, when I want to replace everything except the capacitor with a "two terminal equivalent".
    (Doing KVL at t=0^+ , starting at bottom through U,Rs,Rc(no current so=0),Uab
    Since then my KVL around is Uab=-U-(-IRs)
    Uab=UT
    answer in book: UT=-U-IRs
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    Okay, so now just track the math.
    Let's call the bottom node 'g', the node at the top of the capacitor 'b' and the top node 'a'.
    As you noted, the voltage on the "south side" of the resistor (node 'g') is higher than the voltage on the north side (node 'a') because the current is entering from the bottom. So
    Vga = Vg - Va = I·Rs = the voltage across the resistor.
    The voltage across the capacitor, Vc, is defined such that it is equal to
    Vc = Vb - Vg
    Because there is no current flowing in Rc, the voltage across it is 0V, hence
    Va - Vb = 0; hence Va = Vb
    Combining these together, we have:
    Vc = Vb - Vg = Va - Vg = -(Vg - Va) = -(I·Rs) = -I·Rs
    For the next part, please show your work -- I'm not sure I'm following your verbal description well enough.
