time delay
Discussion in 'The Projects Forum' started by ankur_s06, May 29, 2011.
  1. ankur_s06
    May 29, 2011
    hey guyz i am trying to build a circuit for generating time delay of 10s but the thing is i want to do it without using 555..is it possible.??how?i want to basically use it with a solenoid forflushing purpose
    tnx
  2. Kermit2
    Feb 5, 2010
    3,846
    963
    YES. Use a micro controller. PICAXE is a common one. Google them up and read all about them.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
  4. CaptainPrice
    Aug 12, 2009
    49
    You will find a lot of time delay circuits you build out of just components have a slow on time, or at least I did....
    Why not use the 555? just curious?
  5. #12
    Nov 30, 2010
    16,665
    7,310
    I have some nice time delay circuits that can go several minutes (max) using a j-fet, capacitors, and resistors, but I have no idea what input signal you want to use or what output voltage or current you need.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Back in the day, we would use a UJT and RC network.
  7. #12
    Nov 30, 2010
    16,665
    7,310
    oscillating the UJT to lengthen the time required to charge a cap?
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    UJT timer would trigger SCR
  9. #12
    Nov 30, 2010
    16,665
    7,310
    Oh. Using the UJT as a comparator (comparing the breakover voltage of the UJT to the voltage on a capacitor).
    Thank you Bill.
  10. BillB3857
    Feb 28, 2009
    2,402
    348
  11. #12
    Nov 30, 2010
    16,665
    7,310
    That's what I was thinking. Hope my words weren't confusing to you. Thanks again.
  12. CDRIVE
    Jul 1, 2008
    2,223
    99
    Here's a discrete alternative. Nearly any small NMOS FET will work OK. None of the component values are critical here.
