I've been reading through some posts from others about time delay relays, but nothing jumps out at me and says, "YES! This is what you need!" So at the risk of sounding noobish, I thought I'd just come out and ask.
What I want to do:
My off road race truck has a dixie horn. It's become our trademark. Right now I have a regular switch that activates a relay, which powers the compressor for the air horn. I have to hold the button down while the horn plays. I'd like to convert the system so that I only have to press the button once to play the whole horn.
Requirements:
I'd like something simple (simple means less likely to break), and robust.
Must work with 12vdc @ 20 amps (if I'm replacing the existing relay, otherwise, I guess I just need enough to trigger that relay)
Single trigger to activate, and stays on for a set period of time from the initial trigger (not from when the trigger is released)
Adjustable length (I'm not sure exactly how long the horn loop is, so I want to be able to fine tune it)
So I ran across one of these: http://www.grainger.com/Grainger/DAYTON-Time-Delay-Relay-5WML9
Seems like it might do the trick, but since I really have no idea what I'm doing here, I thought I'd ask some experts to point me in the right direction.
Thank you in advance.
What I want to do:
Requirements:
