KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
The 24 V LEDs I understood once you clarified.Thanks spinnaker! That makes sense to me.
Kiss, these are 24VDC LEDs.
I guess you're calling my nichrome wire a "heater"? The nichrome wire is bare and 8mm long. It's a consumable fuse, that will heat up and ignite a sample in a high pressure environment.
Other's (alec_t) though the nichrome was a heater too because heating is the usual application.
Not sure why you need the "controlled burn" then? More of a safety issue or don't want a DC field messing up the experiment?
