I'm trying to make a circuit that will start a timer for 4 minutes (approximately) when it receives a positive input signal of 5VDC to 9VDC; the timer will stop and reset if the input signal drops at any time during that period.
If the constant 4 minute limit is reached (which means one of my sensors is probably broken) then it will permanently keep a different line (which also uses 5VDC to 9VDC/10mA) in a permanently open state from what was originally a closed state at startup, and it will permanently power a buzzer (5VDC to 9VDC/7mA).
I need this to be a small simple and dependable circuit that will run for years to come. Any help is appreciated, especially a diagram.
Thank you for your help.
