Time delay circuit
Discussion in 'General Electronics Chat' started by llaadd, Jul 19, 2010.
  1. llaadd
    Apr 27, 2007
    hi,
    I want to create a simple time delay circuit, I was thinking with a 555 timer or something similar.
    The issue I have is that I am modifying an existing circuit which means it has some built in contraints:
    Trigger Voltage: ~1V ( I don't know if this will be enough to trigger the timer)
    Trigger Duration: 0.5 - 1 second
    Circuit Voltage source: 4.5V (if need I can use a higher voltage source and use a pair of resisters to step down the voltage to the 4.5v part of the circuit.)
    Output Duration: ~10-15 seconds
    any advise would be great, thanks
