time activated relay.
Discussion in 'The Projects Forum' started by agapis, Feb 4, 2009.
  1. agapis
    Feb 2, 2009
    hi:
    i have to design a undercarriage for a model hand launched glider for a competition.
    the undercarriage must deploy AFTER 2 seconds, and the glider must remain airborn for at least 5.
    heres the problem: it CANT use radio control.
    so obviously a timer is the way to go.
    i have the mechanical system designed, it just needs a timed actuator to pull the pin. once the pin is released the (torsion) spring loaded frame will deploy.
    so i need a timed servo/rotary dc motor to activate after 2 seconds.
    HOW CAN I DO THIS?
    i have one real life 555 circuit built, and a simulated one in MULTISIM, but the output off the relay is showing decay on oscilloscope. it should be showing a square wave of a specified pulse witdth. it ISNT.
    does anyone know ANYTHING about this kind of thing who can help me? i have spent many hours on google, and all the circuits seem to fail when simulated.
    what i need a is a 5v-12v DC "monostable one-shot" circuit, that starts timing after i press a button, and either keeps the relay open for short/long enough to move my motor OR sends a correctly modified pulse (1.5ms) to my servo.
    any ideas?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    A simple 555 monostable will do the timing, but you need to figure out the mechanics from an electrical signal, also how you want to start the timing circuit.
