I'm trying to design a circuit/product for my degree that checks that an angle is correct. EG. an incline of a slope/ladder etc is correct (say between 25 - 30 degrees) and if it is outside the limit a buzzer goes off. Maybe even have a display to show the angle. I'm trying to do this on a tight budget, i have looked into tilt sensors but the only cheap ones I have seen are the trigger ones with either a ball or tilt switch, is there anything programmable or customizable?
Does this make sense, I am competent in soldering and know the basics, could someone put me in the right direction, any existing circuits out there?
Regards,
Will
Regards,
Will
