Tidying up my final answer on z-transform
Discussion in 'Homework Help' started by u-will-neva-no, Jan 14, 2012.
  1. u-will-neva-no
    Mar 22, 2011
    230
    Hey!
    The sequence of:  x[n] = 1, \frac{1}{2}^1,\frac{1}{2}^2,\frac{1}{2}^3,...
    was asked to be expressed using the z-transform:
    X(z) = 1 +\frac{1}{2}^1z^-^1 +\frac{1}{2}^2z^-^2+\frac{1}{2}^3z^-^3+...
    What I can't do is express the final result into the one on the sheet which is:
     \frac{z}{z-0.5}
    The notes say to use the linear difference equation:
    \frac{x[n]+x[n-1]}{2}
    I found x[n-1] just by subtracting one from each value for x[n] above so when I added the numerator I got 1 and the denominator as 2...clearly it is wrong.
    Thank you in advance for helping!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    This is the sum of a geometric series.
    X(z)=1+\frac{1}{2z}+\frac{1}{4z^2}+\frac{1}{8z^3} + ....
    Since the series is infinite we may write ...
    \frac{1}{2z}X(z)=X(z)-1
    \frac{1}{2z}X(z)-X(z)=-1
    (\frac{1}{2z}-1)X(z)=-1
    (\frac{1-2z}{2z})X(z)=-1
    X(z)=\frac{-2z}{1-2z}
    X(z)=\frac{2z}{(2z-1)}
    X(z)=\frac{z}{(z-0.5)}
    u-will-neva-no likes this.
