ti max232 part help
Discussion in 'General Electronics Chat' started by bomrat, Oct 26, 2013.
  1. bomrat
    Dec 13, 2009
    25
    hi, i have an ezefi programmer , i have a bad chip in, im trying to find the rest of the part number,
    ti (missing numbers) 24kg4
    max232
    its a soic - 16
    it got fried, so i am missing the front part number, any specs or datasheet would be awsome.
    thanks
  2. JohnInTX
    Jun 26, 2012
    2,392
    1,051
    MAX232? If so, its pretty generic. Here's a datasheet. If you are wondering if your chip is a MAX232, check the power pins. +/- on pins 16/15 is the giveaway. Caps on the C1/C2 pins would confirm it. Check the power supply voltage. If 5V, a 232 is fine. If 3.3v use a 3232.
    If that's not exactly it, here are some others.
