TI has announced end of life of LM386
Discussion in 'General Electronics Chat' started by RichardO, Oct 28, 2015.
  1. RichardO
    May 4, 2013
    1,335
    429
    Sad. What are hobbyists going to do when the present supply of the LM386 runs out?
    From the Digi-Key site:
    Part Status: End of Life; Last Time Buy Date: 09-28-2016. Minimums may apply.
  2. GopherT
    Nov 23, 2012
    6,303
    4,019
    absf likes this.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    there are several manufacturers for the lm 386 other than Ti.
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    absf likes this.
  5. Brevor
    Apr 9, 2011
    282
    56
    It's not just the LM386, the list of parts to be discontinued is several pages long. A few others listed are the LM3914/3915 and the LM833.
  6. #12
    Nov 30, 2010
    16,665
    7,310
    Audio Guru hopes the 741 is on the list. :D:rolleyes:
    (newbies: It's an inside joke.;))
    gerty, SgtWookie, nerdegutta and 4 others like this.
  7. crutschow
    Mar 14, 2008
    13,475
    3,362
    No such luck.
    I think the 741 will be around as long as there's analog electronics, especially in third world countries.
    One possible advantage of students using the 741 is that they immediately run into the glaring differences (and deficiencies) between the ideal op amp they studied and a real but poor one in practice (supply voltage limits, offsets, bandwidth, slew-rate, common-mode range, etc). :rolleyes:
    nsaspook, #12 and recklessrog like this.
  8. ian field
    Oct 27, 2012
    4,447
    791
    If they wanted that much of a challenge, they'd bring back the 709.
  9. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    I still have some LM301 chips laying around.
    Are those also on the list?
    For a lot of us it would be a greater loss when the 555 would be on the list.
    Bertus
  10. crutschow
    Mar 14, 2008
    13,475
    3,362
    Sometimes the difference between a challenge and an impossible task can be close. ;)
  11. ian field
    Oct 27, 2012
    4,447
    791
    They might well start phasing out the bipolar version, but in relative terms the CMOS 555 is still new kid on the block.
    Through hole parts of any description are probably at greater risk of being finished off.
    It wasn't all that long ago that Zetex introduced a version of the 555 that can run off a single 1.5V cell.
  12. GopherT
    Nov 23, 2012
    6,303
    4,019
    It would be amazing if TI would come out with a great replacement for the LM386. <0.1 THD, 1 Watt, Ultra-low noise, wide input voltage range, wide amplification range, low input, DIP Package for hobbiests
  13. ian field
    Oct 27, 2012
    4,447
    791
    Wasn't the LM386 originally a NS part?
    NS do various AF PA chips that far exceed the 386 in performance.
    http://media.digikey.com/pdf/Data Sheets/National Semiconductor PDFs/LM4831.pdf
    But I'm not sure whether there's any through hole parts.
  14. Brevor
    Apr 9, 2011
    282
    56
    Yes, TI recently purchased NS and now they are discontinuing a lot of old NS parts.
  15. GopherT
    Nov 23, 2012
    6,303
    4,019
    Like a lot of acquisitions. After some executive decides to buy another company, the product managers and technology people decide that most of it is a pile of $h!t.
  16. ian field
    Oct 27, 2012
    4,447
    791
    As long as people keep paying for the parts - small SE Asian firms will keep making them.
    absf likes this.
  17. crutschow
    Mar 14, 2008
    13,475
    3,362
    Wishful thinking, I'm afraid. :(
    GopherT likes this.
  18. ErnieM
    Apr 24, 2011
    7,435
    1,625
    DIP packages themselves are on the endangered species list.
  19. WBahn
    Mar 31, 2012
    18,085
    4,917
    It would be nice, but volume manufacturer's aren't going to do much of anything for the hobbyist. If doing so is truly a low=cost, low-hanging fruit, then maybe. But it's not going to be a decision driver.
  20. nsaspook
    Aug 27, 2009
    3,009
    2,352
    It's more about what old equipment can still be supported and what can easily be re-qualified on new equipment. Most of these old line parts are still being made on 6 inch 20+ year old equipment that's running on shoe-strings and bailing wire in a FAB that's long past it's prime. The safety requirements for legacy installs are pretty lax but when you have to consolidate equipment to another location it must meet modern requirements. People are currently dealing with some major technology transfer issues with products from old-school acquisitions. If you have a critical need for something from a company that was recently swallowed up by another, my advice is to buy what you need NOW.
    SgtWookie and GopherT like this.
