TI-89 HELP: TI-89 LINK WITH COMPUTER
Discussion in 'Homework Help' started by ees1, Sep 23, 2008.
  1. ees1
    Thread Starter Active Member
    Jan 7, 2008
    37
    Hi, I have checked the guidebook and also TI website, and I couldn't find any information for:
    The TI-89 has a function called text editor, and it is kind of tedious if you typed long information via its keypads. So far I couldn't find the answer if it is possible that you could type notes in your desktop and then transfer them to TI-89 because TI did sell the USB link cable.
    What I am trying to do is to store some equations in TI-89, so far I only found the text editor can let you type anything you want. any suggestion?
  2. thisguy692
    Jul 27, 2008
    5
    Haven't used it in a while but i believe that you can get the notefolio program off the TI website. With that program you should be able to type on the comp then transfer to your 89.
  3. ees1
    Jan 7, 2008
    37
    Thank you very much!
