Does that actually work?you can also just right click, copy then paste if it on the web ANYWHERE already also.
thats the easiest!
Yeah, I've just tested it, you have to use the full WYSIWYG editor to be able to use that method.Does that actually work?
It might if you use the WYSIWYG editor but doesn't with the standard (or basic) editor.
Dave
Following your sequence above, it doesn't for me.Worked for me in the basic one
Weird! hmmm.Still no. For me it only works with the WYSIWYG editor.
Dave
Which is the same as using the IMG-tags as per my first post.You mean you have to click insert image then type in the url?
What You See Is What You Get.what is WYSIWYG?
Some people also use you user album which is like a local Photobucket. Works in a similar way where it gives you a fixed URL for the image which you then place in-line with your message using the IMG-tags.As for the format, are you uploading to AAC and then using the URL for that uploaded image? Under the advanced options, go to manage attachments. Browse to the image you want (presumably from your local PC), click on it, then upload. Right click on the uploaded image to get its url at AAC, etc. as described above.
Thread starter | Similar threads | Forum | Replies | Date |
Thumbnail track pad | Off-Topic | 0 |
Similar threads |
by Aaron Carman
by Aaron Carman
by Jake Hertz
