through hole zeners instead of surface mount
Discussion in 'General Electronics Chat' started by jimmiegin, Apr 7, 2014.
  1. jimmiegin
    Apr 4, 2014
    49
    Hi all.
    Just a quick question that I hope will have a simple answer.
    I am looking for through hole zener diodes with the same specification as these:
    Z1 BZV55C24
    Z2 BZV55C3V3
    Z3 BZV55C6V2
    Z4 BZV55C3V3
    Now I really hope it is as simple as changing suffix or prefix. Any help will be vary much appreciated.
  2. kubeek
    Sep 20, 2005
    4,689
    806
    Try BZX55C24 etc. These should be the same but in DO35 package. Also BZX79 seem to be the same too, check on farnell for example.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    If you get same or (somewhat higher is also OK) max power dissipation(wattage) and zener voltage. You can select from what you find available in through hole zeners
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    1N52xxB looks like a direct cross.
    Good luck.
