Through Hole Equivalent for BAS16, BAT54S
Discussion in 'The Projects Forum' started by markH, Oct 9, 2011.
  1. markH
    Dec 5, 2009
    14
    I wish to build a circuit which calls for BAS16 and BAT54S diodes; these appear to only be available now as surface mount devices. What would be satisfactory through hole equivalents? TIA.
    Mark
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  3. markH
    Dec 5, 2009
    14
    Thanks for the lead.
    Best as I can tell:
    2 x BAT85 through hole should be equivalent to the BAT54S dual surface mount.
    A 1N4148 through hole should suffice for the BAS16 surface mount.
    Do you see any issues with these substitutions? TIA
    Mark
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    They look reasonably close, but hard to tell for certain without seeing the circuit.
  5. markH
    Dec 5, 2009
    14
    The circuit is for a 1-Wire DS2450 ADC. I found another reference source (attached) where 1N914 is used in lieu of BAS16 and 2x1N5617 is used in lieu of BAT54S.
    Thanks.
    Mark
