three questions for logic circuits
Discussion in 'Homework Help' started by ahmedalfares, Feb 11, 2016.
  1. ahmedalfares
    Feb 11, 2016
    hello I have three questions for logic circuits. If you can help me pleas.
  2. crutschow
    Mar 14, 2008
    13,462
    3,353
    This sounds like it should be in the homework section.
    Sorry, we don't do homework here, but we will help you with yours if you show what work you have done to try to solve the problem.
  3. ahmedalfares
    Feb 11, 2016
    First one. I choose 1.6
    Second . I choose 250
    Third . 471
    Noo this is was my homework. I did it but i am waiting the solution. I want to know the solution before the exam today.
    So pleas if you know the answer. Tell me. I need to know. Thank you so much
  4. ahmedalfares
    Feb 11, 2016
    Third . 471
  5. crutschow
    Mar 14, 2008
    13,462
    3,353
    Only your second answer is right.
    How did you calculate the other two values?
  6. ahmedalfares
    Feb 11, 2016
    Can you tell me how can I calculate them ?
  7. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You still don't get the program. You show us what you did and how you got your result. Then, and only then, do we show you where you went wrong. You'll remember things for the exam much better if we do it this way. You can continue to insist on your way, but if you do, then we can't help you because we don't know what you don't understand about the problem. Only by seeing where you went wrong can we provide the information that you need. Do you get the idea?
  8. crutschow
    Mar 14, 2008
    13,462
    3,353
    All you need is basic arithmetic and Ohm's law.
    I assume you are familiar with both?
