Three Phase Y-Connection Line Voltage ?
Discussion in 'Homework Help' started by Xufyan, May 17, 2011.
  1. Xufyan
    Aug 3, 2010
    114
    for 3-Phase Y-Connection the Line Voltage is,
    VL=\sqrt{3}xVp
    This can be proved using this equation,
    Vab = Van + Vnb , looking at this circuit, how this equation is derived ?
    please help
  2. jegues
    Sep 13, 2010
    735
    43
    V_{ab} = V_{a} - V_{b}
    \text{Because, } V_{a} = V_{m} \angle 0^{o} \text{ and } V_{b} = V_{m} \angle -120^{o}, \text{ we have,}
    V_{ab} = V_{m} - V_{m}(-1.5 - j0.866)
     = V_{m}(1.5 - j0.866)
    V_{ab} = \sqrt{3}V_{m} \angle 30^{o}
    Similarly,
    V_{bc} = \sqrt{3}V_{m} \angle -90^{o}
    V_{ca} = \sqrt{3}V_{m} \angle -210^{o}
    Thus the line-to-line voltage is √(3) times the phase voltage and is displace 30° in phase.
    EDIT: After reading your post, I may have misinterpreted your question.
    If you are asking where the equation,
    Vab = Va-Vb comes from,
    see the figure attached.
      File size:
      20.5 KB
      68
    Xufyan likes this.
  3. Xufyan
    Aug 3, 2010
    114
    the attached figure solved my problem :)
    thanks alot
