three phase systems
Discussion in 'Homework Help' started by jim, Jan 24, 2006.
  1. jim
    Jan 24, 2006
    Hi to all the experts out there,
    I'm completely stuck with 2 homework questions if anyone can help you would be my life saver. Its basically just starting off and being 100% sure if I'm correct or not at the beginning. As you well know if you can answer these types of questions correctly if incorrect all the answers that follow on are also incorrect.
    1) A symetrical 3 phase, 400V system supplies a balanced delta connected load
    the black to brown branch 20 /_40 degrees A
    Line Current
    The total power
    2) A three phase, four wire, 440V system is loaded as follows:
    .. an inductive motor load of 350KW at 0.707 lagging
    .. Resistive loads of 150KW,250KW and 400KW connected beteween the brown, black and grey lines to neutral
    sequence is Br / BL / GR
    Line Current
    The Current in the Neutral
    The Overall Power Factor
    If nothing else can anyone just push me in the right direction ( line current is the problem ) and my conversion from polar .
  2. chesart1
    Jan 23, 2006
    For future reference, pick up Schaum's Outline of Electric Circuits. It is a great reference for help when solving homework problems.
    Please include the progress you have made thus far in each problem.
    Also in the first problem, please refresh my memory by defining the 20/_40 Degrees A.
    Thank you
