three phase system
Discussion in 'General Electronics Chat' started by ols1570, May 18, 2014.
  1. ols1570
    Dec 3, 2013
    9
    Hello everyone
    I ve bought three inverters dc to ac. The input is 24V dc and output 230V ac. Each of them 3kVA. I want to link them together to obtain three phase system 400V. Any idea if i can make that?
    Thank you
  2. crutschow
    Mar 14, 2008
    13,475
    3,362
    You will need some method to synchronize them together with a 120 degree phase angle between them. If the inverters don't have a sync input (unlikely) then you would need a circuit diagram to determine how that could be done.
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    3ph Transformer or 3 separate ones Star or delta the outputs.
    Plus what Mr Crutschow said.
    Max.
  4. ols1570
    Dec 3, 2013
    9
    each phase is 230V with respect to the neutral. I need to take to lines to make 400V. But the problem is time and angle between them
