Three phase system
Discussion in 'Homework Help' started by feferry, Dec 8, 2005.
  1. feferry
    Dec 8, 2005
    How would you determine proper phase sequence using an oscilloscope. Please detail connections and procedure.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Pick a phase as a reference and display on ch 1. Pick another & see if it leads/lags the reference.
    Another quickie - if the motor runs the wrong way, just swap any two phases to correct.
  3. Sebi
    Sep 24, 2005
    59
    Or You can build a small flip-flop cct. for testing.
  4. dougp01
    Member
    Dec 6, 2005
    27
    Three phase systems operate on 120 degree angles. If you reference phase A with one o'scope probe, a second scope probe will show phase B lagging A by 120 degrees, and phase C should lag A by 240 degrees.
