Three phase system question
Discussion in 'Homework Help' started by Manuel Faria, May 5, 2016.
  1. Manuel Faria
    May 5, 2016
    I have the following circuit. Three phase generator, direct sequence
    The goal is to calculate i3.
    I know that e3(t)=200sqrt2cos(wt)
    C=1mF w=1000rad/s
    P=10kW Q=10kVAr
    P*=10kW Q*=-5KVAr
    What I'm doing:
    e1(t)=200sqrt2cos(wt-120)
    e2(t)=200sqrt2cos(wt-240)
    i3+i3'(capacitor)=i3''(load)+i3'''(load*)
    i3'=V2(phase)/Zc
    i3''=S/(sqrt(3)*VL)
    i3'''=S*/(sqrt(3)*VL)
    My doubt is in i3'' and i3'''
    i3'=200sqrt2e^j(-240º)/j=283e^j(30)
    i3''=10000sqrt(2)e^j(45)/sqrt(3)sqrt(3)200sqrt(2)e^j(30)=1,6e^j(15)
    i3'''=11180e^j(27)/sqrt(3)200sqrt(2)e^j(30)=22,8e^j(-3)
    Is this procedure correct? Thanks
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    I don't see anything that indicates whether or not the 3-phase load is balanced. Is it?
  3. Manuel Faria
    May 5, 2016
    It just says that the network three phase network is powered by three symmetric direct voltages.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Then you don't have much of a realistic choice but to assume that it is balance, but you should be sure to make a note that you are making that assumption.
    Manuel Faria likes this.
  5. Manuel Faria
    May 5, 2016
    So the way I'm thinking it is correct?
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Possibly. I'm just not willing to wade through your work unless you go back and track your units through the work properly.
