Three Phase Rectlifier with PSPICE need help
Discussion in 'The Projects Forum' started by Pellz, Dec 9, 2013.
  1. Pellz
    Nov 27, 2013
    10
    I created Three Phase Rectlifier and i need get function UL = IL. Anyone can help how to get?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What is UL and IL? Define these terms.
  3. Pellz
    Nov 27, 2013
    10
    voltage (U) inductor (L)= Current (I) inductor (L)
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    What has inductance got to do with a rectifier?
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Where is there an inductor in any rectifier? Post a schematic of the circuit you are trying to analize, or at least the netlist...
  6. Pellz
    Nov 27, 2013
    10
    here my rectlifier scheme
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    So what is the problem? Are asking us "how do I use PSpice"?
  8. Pellz
    Nov 27, 2013
    10
    i need to know how to make characteristic UL = IL, where put the voltmeter?
  9. Alec_t
    Sep 17, 2013
    5,980
    1,138
    ?? If UL is a voltage and IL is a current they can't possibly be equal.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    When LTSpice makes this sooo easy, why use PSpice?
    Note how easy it is to name a node, then display the voltage at a node, display voltage between any two nodes, and the current through any component...
  11. Pellz
    Nov 27, 2013
    10
    thanks :) pspice recommended my supervizor
  12. MikeML
    Oct 2, 2009
    5,451
    1,066
    Then show your supervisor my LTSpice sim and its results.
  13. Pellz
    Nov 27, 2013
    10
    That simulink result was good, i have another task: UL = f(IL) UL = f(diode) how to get it? Now it is function, scheme same.
