Three Phase Inverter
Discussion in 'General Electronics Chat' started by electronic_engineer, Aug 2, 2016.
  1. electronic_engineer
    Aug 2, 2016
    10
    Dear
    Please answer this question, I found it as an MCQ:
    What is the output waveform of Three Phase inverter connected in Star connection and conduction angle is 120 degrees?
    Different options were square wave, quasi square wave, six step square wave etc?
  2. tcmtech
    Nov 4, 2013
    2,113
    1,751
    The same as three single-phase inverters with a 120-degree shift from one to the next.
  3. electronic_engineer
    Aug 2, 2016
    10
    would it be six step square wave?
  4. DickCappels
    Aug 21, 2008
    2,772
    669
    In the case in which large harmonic content is ok, yes. Or it could be a 360 step sine wave, or...
  5. tcmtech
    Nov 4, 2013
    2,113
    1,751
    If that's what you want for each phase.
    The waveforms will be whatever you chose to make them. The three phase definition just means that there will be three of them with a 120-degree timing separation between them.
    Methinks your title of 'electronic engineer' does not fit your knowledge base. :rolleyes:
  6. electronic_engineer
    Aug 2, 2016
    10
    I have been untouch with all such things for a very long time and now need to revise the basics
