three-phase half-wave rectifier
Discussion in 'Homework Help' started by kenny-one, Feb 24, 2011.
  1. kenny-one
    Apr 21, 2010
    37
    hey guys, a have a problem, and i dont seem to be getting anywhere near to an answer, so pls help here:
    A three-phase half-wave rectifier is feeding power to a highly inductive load. It has a
    supply voltage of 150 V/phase. Determine the mean load voltage and the required
    diode rating, assuming the load current is level at 25A. Assume each diode has a voltage drop
    of 0.7 V.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think the mean load voltage would be \left( V_{peak}-2\cdot 0.7 \right) \cdot \frac1{\frac{2\pi}{3}} \int_{-\frac{\pi}{3}}^{\frac{\pi}{3}} cos(\phi) d\phi
    Someone correct me if I 'm wrong.
