I hope all goes well in your kludge'pedition. Dodging bullets can be a demanding task.
I'm not sure if you are looking for a characteristic of the SCR's or just a part number. The part number they are labeled with is N023RH12. Then there's the small logo and another bit of text "B020."
Westcode Semiconductors
"Convertor Grade Stud-Base Thyristor Type N023R"
PDF Datasheet - N023RH12.pdf
Regarding the BAP1950's J5 connector and its three-phase references lines, the lines should be disconnected from the brake circuit when the BAP1950 is not live and in control of the SCR's?
Are the three lower diodes installed to work as quenching diodes, like would be used in an automotive relay setup? (Possibly called a suppression diode)
I ordered the BAP1950 and the NI USB-6211. The BAP1950 will take four weeks to arrive. The DAQ should be here within five business days.
