three phase controlled rectifier THD
Discussion in 'Power Electronics' started by abdelazez, Jul 18, 2016.
  1. abdelazez
    Jul 3, 2016
    Untitled0.png hello every body
    I've already built a three phase controlled rectifier for use it as a battery charger with the flowing spics:
    input voltage: 380 Vac
    input frequency: 50 HZ
    output nominal voltage: 110 Vdc
    output current: 50 Adc
    also i used a delta-star transformer as a isolation transformer almost every thing is gone perfectly but i have a big problem with total harmonics distortion so the transformer temperature rise up and i have bad efficiency, I've used the configuration in attach
