Three Phase BLDC and Hall Effect Sensor Questions
Discussion in 'The Projects Forum' started by Jin Ming, Mar 1, 2016.
  1. Jin Ming
    Oct 26, 2015
    5
    Hi all,
    I have recently acquired a BLDC that has no datasheet or any in-depth wiring diagram.
    I am new to the field of motor and motor control and I am trying to build a controller for this motor. So, I have some questions,
    1) How do I determine the correct commutation sequence to the 3 phases based on the 3 hall effect sensor which has no label or their known location in the stator without guess work? (Meaning, I'd like to know which wires corresponds to Hall A, B and C so that my microcontroller can generate the commutation correctly)
    2) Can a motor have odd-numbered poles? I know the teeth on the stator does not really imply how many poles it has and from my classes, motors seemed to have even-numbered pole pairs. This image is taken from the web, and can someone guide me on how to determine the number of poles of this motor.
    3) How do I go about measuring the Back-EMF of each phase of a BLDC and maybe displaying it on an oscilloscope? (I'd like to see the trapezoidal BEMF of the motor on a oscilloscope for my understanding). Do I connect the probe (ie. Channel 1) to Phase A, and the ground to Phase B?
    Many thanks.
  2. MaxHeadRoom
    Jul 18, 2013
    10,872
    2,528
    Even number of poles only on a BLDC motor.
    Short all 3 stator connections, spin by hand and count number of 'bumps'/rev for pole count.
    Here is the commutation using Hall effect equivalent tracks, shows the back fed wave form from the stator windings, sinusoidal not trapezoidal.
    There is also a method that initially exercises the motor to acquire the relative pole positions and from then on use an encoder to track pole position.
    BTW, you connect a 10k resistor to each stator lead and connect all 3 resistors together to provide a virtual Zero reference for the 'scope gnd lead.
    Max.
