Hi, I've got quite a simple circuit to build around a PIC10F222, but having written the program and made up a test ciruit board it's not behaving as I was hoping and I was hoping I could get some thoughts from this forum. I'll check over my program first.
The idea is very simple; the uC starts with 2 of its I/O pins in output mode set high. When the ADC (GP0) reads a voltage above a certain limit, these 2 I/O pins (GP1 and GP2) switch low and never switch back high, no matter what the ADC measures until the uC is reset.
I have included my test code. Apart from plenty of optimisations that could be made, should this code do as I've outlined above? The board I have made up does not seem to do this And I'm struggling to figure out what's the problem, but the software should be easiest to check first.
It seems to work as expected, except that it switches off the I/O pins at a VERY low voltage. In the code I have it set to switch at around half the working voltage (around 2.5V running the chip at 5V) but it actually switches at around 0.007V (consistantly, I'm using a Fluke DMM to measure this). I'm using a 1k pot to set the ADC voltage so I think this should be fine.
If the code is fine, I at least know its something wrong with my test board.
Rich (BB code):
LIST P=PIC10F222
#include p10f222.inc
ERRORLEVEL -302 ; Supress bank switching messages
__config _MCLRE_ON & _CP_OFF & _WDT_OFF & _MCPU_OFF & _IOFSCS_8MHZ
org 0
limit equ 0x10 ;Location to store voltage limit.
movlw d'128' ;Conversion: 1 = 0.01953125V
movwf limit ;Move into F
movlw b'11011111' ;Set up option bits
OPTION w ;Set Option bits
movlw b'01000001' ;Set up ADC to use AN0/GP0
movwf ADCON0 ;and move into ADC register
movlw b'00001001' ;Set up GP1 and GP2 as outputs
TRIS 0x06 ;and move into TRIS
bsf GPIO,GP1 ;Set output High
bsf GPIO,GP2 ;Set output High
start clrwdt ;Clear watchdog timer
bsf GPIO,GP1 ;Make sure output is high (not needed?)
bsf GPIO,GP2 ;Make sure output is high (not needed?)
bsf ADCON0,GO ;Start ADC cycle
ADCBegin btfsc ADCON0,NOT_DONE ;Evaluate if ADC is finished
goto ADCBegin ;Not done so keep checking
movfw ADRES ;ADC finished. Move result into W
subwf limit ;Subtract result from limit
btfsc STATUS,C ;Evaluate if it went less than 0
goto start ;Voltage less than limit, retest.
warning bcf GPIO,GP1 ;Voltage is over limit, set warning pin
bcf GPIO,GP2 ;Voltage is over limit, set warning pin
clrwdt ;Keep watchdog timer clear
goto warning ;Stay in warning loop
end
