thoughts for a latching circuit
Discussion in 'The Projects Forum' started by nmc240, Apr 9, 2010.
  1. nmc240
    Mar 12, 2010
    21
    I have a sensor that gives a signal that varies from 0-4.5V the sensor is powered by 12 volts. The question I have is how do I get the signal to latch and hold at 4.5V once it has reached 4.5V, until there is a power off?
    Any help would be appreciated.
  2. Bernard
    Aug 7, 2008
    4,240
    414
    1. Low power SCR, [ 2N5060 ], needs inverting to have a high output.
    2. Flip-flop
    3 Latching relay with driver
    4. Dual input optical coupler
    5. ?
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Some sort of analog, comparator-triggered, sample-and-hold
    Maybe a PIC with an ADC input and a DAC (PWM/low pass filter) output.
    Ken
  4. sgardner025
    Nov 5, 2009
    79
    Maybe a latching comparator IC.
  5. nmc240
    Mar 12, 2010
    21
    Sorry for the long time between replies, I was out of town over the weekend. I have looked at all of the ideas and one thing I noticed was that there was no cheap way to do it. Is there a cheap way to do this?
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    Can you elaborate? Is this an automotive project? Does the sensor voltage drop below 4.5v after it reaches that value?
    Ken
  7. nmc240
    Mar 12, 2010
    21
    Yes this is an automotive project. The signal I need to latch goes from 0-4.5V depending on the pressure is applied to the gas pedal.
  8. rjenkins
    Nov 6, 2005
    1,015
    69
    Sorry, the forum policy does not allow projects that could affect vehicle safety & connecting in to the throttle control is a very hazardous thing to do.
  9. nmc240
    Mar 12, 2010
    21
    It actually doesnt attach to the throttle. I used a IR LED and Poximity sensor to measure the distance from the pedal to the floor.
  10. nmc240
    Mar 12, 2010
    21
    Kinda changed directions alittle bit, Just wondering if this looks like a viable option for peak and hold.
    Would this make the signal stay at the highest level that it reached until the switch was closed?
  11. KMoffett
    Dec 19, 2007
    2,584
    234
    Yes...for a while. The capacitor will slowly discharge.
    Ken
  12. nmc240
    Mar 12, 2010
    21
    What would be a good op amp to use for this i tried a lm358 but it is not working at all for me?
