I have two (Fuji 974222 NPN) transistors on this forklift. I can't find much out on these ( somewhere I seen they could be 50 amp). I have used the diode check and the ohm scale on my meter. I have used the standard diode check and tried to ohm them out but they have me stuck. On the diode scale the meter will not stabilize and the ohm's is reading wierd.
I need help trying to figure if they are bad.
Thanks jjr
Thanks jjr
