1)Design and draw the basic differentiator circuit
with RC time constant 1second.Draw the output
waveform for the input signal of V=2sin (10pai t)
where t is in seconds.
2)Using IC LM317,design an adjustable voltage
regulator for an output voltage of 2 to 10 volts.if
the dropout voltage and ripple voltage for this IC
is 3v and 2v respectively then what the minimum
voltage that should applied at the input to get 10v
output.
output.
