this is auto cut-off charging circuit,how to connect this circuit?
Discussion in 'The Projects Forum' started by qaisershah, Dec 11, 2015.
  1. qaisershah
    Nov 21, 2014
    18
    i got this circuit from local market ...i know little bit of electronics...how to connect this circuit...
    i am using it for a battery charging and this is auto cut-off charging circuit.
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
    I would supply it at the +/- contacts as per the instructions it came with, adjust the preset resistor until the relay clicks in/out, use the relay contacts to disconnect the charger .
  3. qaisershah
    Nov 21, 2014
    18
    if i understand your answer correctly , you said i have to connect +/- with battery terminal and others with main supply? i have simple bridge rectifier supply , how to connect it with this circuit?
  4. Dodgydave
    Jun 22, 2012
    5,141
    767
    The +/_ to the battery terminals, and the relay contacts Com and No, or Nc in series with the positive supply from bridge rectifier to battery positive, negative bridge rectifier to battery negative.
    What voltage range does the circuit need?
    qaisershah likes this.
  5. qaisershah
    Nov 21, 2014
    18
    Thanks alot friend..appricaited.
  6. qaisershah
    Nov 21, 2014
    18
    12V
