third order butterworth (ind,cap,ind)
ninjaman
Joined May 18, 2013
341
hello
please could someone point me in the direction of a site that includes formulas for rlc networks. I have to find current and voltage through three components in a circuit. an inductor in series, a capacitor in parallel and another inductor in series. its a third order butterworth passive filter.
I have found formulas but only for one inductor in series and one capacitor in parallel.
does much change when you add another inductor in series?
I mean when working out the current and voltage?
do you have to include all three components in the formula or can you do the first two (inductor/capacitor) and then using that result for the second series inductor?
all the best
simon
shteii01
Joined Feb 19, 2010
4,644
Replace inductors and capacitors with impedances.
Inductor becomes sL.
Capacitor becomes 1/(sC).
Now you can treat them like resistors. Do the voltage dividers, current dividers. Resistors in series. Resistors in parallel.
gootee
Joined Apr 24, 2007
447
You could use only jω, instead of s = α + jω. But then you would get only the sinusoidal steady-state response and lose the transient response portion. You would basically be downgrading from Laplace to Fourier.
With Laplace, you are essentially converting the full differential equations of a circuit or system into algebraic equations in terms of s, which are usually much easier to solve than the time-domain differential equations. After the algebraic equations have been solved, you can keep the solution in terms of s, and have the traditional frequency-domain Transfer Function, or directly convert back to the time domain solution of the differential equations.
For the OP: You can treat each reactive component as a frequency-dependent resistance and then use the standard methods of basic resistive circuit analysis (i.e. writing the node and/or loop equations, using Kirchoff's current and voltage laws, and then solving the set of simultaneous equations).
LvW
Joined Jun 13, 2013
1,752
Don`t forget the phase properties! A frequency-dependent resistance (FDNR) is something else!
gootee
Joined Apr 24, 2007
447
I wasn't forgetting anything!
The resulting equations would completely characterize not only phase and amplitude in steady state but also the combined transient response and steady-state response solution, if s were used instead of only jω!
I was NOT suggesting evaluating the impedances at some frequency, first, and then analyzing a resistive network. I was suggesting that the OP should try to realize that the frequency-domain expressions for the components' impedances could be used in the same way that resistances are used, when writing the equations for the circuit network.
Some beginning EE students experience a significant "Aha!" moment when they first realize that a first-order RC filter can be seen as a frequency-dependent voltage divider, for which they can write the equation very easily.
LvW
Joined Jun 13, 2013
1,752
gootee,
I know what you mean - however, I don`t think that your explanations are consistent.
Treating a capacitor/inductor just as a "frequency-dependent resistance" means to write 1/wC and wL, respectively (without the imag. symbol j).
Now - combining these expressions for calculating a voltage divider provides no phase information at all.
All I wanted to say in my short remark (post#8) is that the correct expressions 1/jwC or jwL should NOT be called "frequency-dependent resistances" but instead "impedances".
(Believe me, I also have some experiences (25 years) with EE students)
