With every reaction there's an equal opposite reaction, but just how close are we right now in almost 100% efficiency, there's always energy losses so i started racking my brain out..
If you stored compressed oxygen under water and simply had a pulley of some kind, inflating a huge rubber object with the compressed air, that would then float up to the surface pulling up/down on a pulley system which then gets converted into electric and supplied out to the grid..
But here's my logic, if it's deep enough below the sea as it rises all the way up to the top of the water, do you think it's possible to produce more energy back than what you did to begin with to compress the oxygen into liquid form and then into the cylinders... maybe build a power station at the bottom of a deep sea bed along with a lot of pulleys, when it reaches the top, the object deflates and it sinks back down to the floor again..
have multiples of this system going producing the compressed oxygen at the bottom of the sea maybe with pipes leading down to supply the oxygen, 10 - 20 - 50 of these all going, imagine doing a mile under water or 2 or even 10... it is the sea after all so size is not a big deal and oxygen or even air from the surface can simply be pumped down not even compress the oxygen, just pump and fill and off it goes, at the top it deflates and slowly comes back down again more air goes in (have 10 - 20, 1000 who's going to care under the sea)
Do you think this is even a viable option? it's not exactly 'over unity' just taking the advantage of air and water, my concern is how much energy is required to pump it down, if it's more than what you get out, this idea's gone, anyone else have any thoughts on this?
