I have a 9v circuit board in a metal case (that adds a sound effect to an audio signal, but that's beside the point). The proper way my diagram says to hook up the 9v DC power is to have the -ve output from the DC converter hooked up to "gnd" which I presume is the ground. Consequently, the positive end is hooked up to "9v IN(+)" which is clearly marked with a + sign. So here's my dilema. My audio jack has an audio signal ring(basically a contact that the audio plug touches when plugged in) and a ground ring, also the jack is meant to be set up with the ground ring sitting against my metal case. I have attached my ground ring wire to the ground on the circuit board too!! . But now that means that my metal case is "hot" and I feel that the two grounds have different meanings and shouldn't be connected. Are the two grounds (for the cicuit board and the audio jack) too different in their function to be hooked up to each other? (let's assume I wired the circuit board correctly 'cause it works and reversing the polarity just makes it start smoking LOL)
