thevenin's theorom
Discussion in 'Homework Help' started by mmuk99, Dec 3, 2007.
  1. mmuk99
    Dec 3, 2007
    hi, im new to the forum so im not sure this is the right category.
    any way.
    i have this circuit consisting of parallel and series resistors.
    the problem for me is that i cannot figure out how to add up all the resistors
    if you guys could help me to make rth, i think i should be able to do the rest.
    MY RLOAD IS R4
    thanks
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Without a sketch of your circuit, we are powerless to assist you with your question.
    hgmjr
  3. mmuk99
    Dec 3, 2007
  4. JoeJester
    Apr 26, 2005
    3,403
    1,230
    mmuk99
    What work have you done on the problem so far?
  5. mmuk99
    Dec 3, 2007
    hi
    iv literally drooled over text book but have not been able 2 do neting
  6. JoeJester
    Apr 26, 2005
    3,403
    1,230
  7. The Electrician
    Oct 9, 2007
    2,301
    339
    When you say that R4 is the load, do you mean that you need to remove R4 and then calculate the Thevenin equivalent of all the rest?
  8. bubbaUK
    Nov 23, 2007
    6
    Replace both voltage sources (V1 & V2) with nothing by removing them and then:
    Add up R6,R2,R3 in parallel. Add the parallel combination of (R6,R2 & R3) with R1 and R7 in series
    Good Luck
    You can solve this by using the superposition theorem too but that would be longer..
