I was recently assigned this problem for homework. I needed to find the Thevenin equivalent circuit, more specifically, the voltage across terminals A and B. I know with a dependent source we must excite the circuit to obtain a value for the Thevenin resistance 'Rt'. I was told to use nodal analysis along with the 'voltage open circuit and current short circuit method'. I am familiar with both mesh and nodal analysis however this problem has been giving me a hard time and any advice would be greatly appreciated. The answer I obtained for voltage at terminals A,B was 6v. Thank you.
*Dependent source is 0.5Ix where Ix is the current along the 10 ohm resistor
