I like to find Eth, Rth and I at 6 ohm resistor...see attachment.
Right here is where you made your error. You have to add in the 3 amp current source. This will make Isc = 4.5 amps. I think the rest of it will work out if you do that.6 +(V1) -Eth +3(V1) = 0
6 +4V1 -Eth = 0
since 6 ohm resistor open circuited 3A will go V1, hence
V1 = 3
Eth = 6 + 4*3 = 18 volts
solving for I short circuit:
Isc = 3 - V1
6 + V1 +3V1 = 0
V1 = 1.5
Isc = 1.5 A
Rth = Eth/Isc = 18/1.5 = 12 ohms
solving for I at 6 ohms:
I = Eth/(Rth+6) = 18/(12+6) = 1 A
Checking the answer:
6 + (V1) - 6*I + 3(V1) = 0
6 + 2 - 6*2 + 3*2 = 2,
Can someone help me to correctly solve this by Thevenin's Theorem?
Thanks!
Thread starter | Similar threads | Forum | Replies | Date |
E | Thevenin's Theorem | Homework Help | 5 | |
Thevenin's theorem BJT derivation | Homework Help | 7 | ||
J | Using Thevenin's Theorem to work out the voltage across a load | Homework Help | 3 | |
Thevenin's theorem QUESTION any help? | Homework Help | 3 | ||
I have had a problem with Thevenin's theorem | Homework Help | 9 |
by Jake Hertz
by Duane Benson
by Duane Benson
by Jake Hertz
