Thevenin's theorem problem
Discussion in 'Homework Help' started by Nur Adhyaksa Hamid, Nov 5, 2015.
  1. Nur Adhyaksa Hamid
    Oct 20, 2015
    Hi guys! Currently i've been learning on circuit principle particularly in Thevenin's theorem. I'm using Ralph J Smith's book but the explanation there is bit confusing. The steps to solved the problem is just hard to remember because it's jump over anything and i thing less systematic than what i found in All About Circuits. Usually, indeed i use Ralph J Smith's procedure. But the procedure is easy to forgotten. So, i search for easier method to remember and i found here.
    But, i've found some trouble in here. There are one step that i don't know how to find, that is find R thevenin. Here is the screenshot :
    I hope there are someone that will give explanation how to get 0,8Ohm resistor. Thanks.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    R1//R3 = 4*1/(4+1) = 4/5 = 0.8
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    How can you study Thevenin's theorem if you don't know the basics ? This two resistors are connected in parallel, and everyone should know how to find equivalent resistance for this type of a circuit. This is really basic stuff. So you should start here :
    https://en.wikipedia.org/wiki/Series_and_parallel_circuits#Resistors_2
    http://www.allaboutcircuits.com/tex...chpt-5/what-are-series-and-parallel-circuits/
    Or even here if you don't know the Ohm's law:
    http://www.allaboutcircuits.com/textbook/direct-current/chpt-2/voltage-current-resistance-relate/
